- Jul 23, 2011
- 52,459
it will dry after a bit of soaking. however with the foam and the dap weldwood (better than the 3M 77, however not as convenient) you may simply want to use epoxy as that is cured in a few hours
Are you saying the OTWS will attack the foam? or cause adhesion problems? It is the new style of urethane upholstery foam that lets water immediately drain through . . .
I'd rather not have to fiddle with epoxy, and want something that soaks in really well.
If you don't think you'll have the boat another 20 years why not just do nothing, it lasted the first time. Could always just coat the exposed areas
Wish I knew of someone to call and ask. What about the place you got the vinyl from, or a local vinyl/canvas shop?
