time to replace power trim relays on merc 90hp 2001 again?
wn6ngp
I went out boat riding Friday and when I first started to launch there was no up trim only down trim. After some vibration that relay started working so I went out and no more problems. This kind of thing happened about 7 yrs ago where it was intermittent and then stuck wouldn't go up. I replaced both relays back then and it solved the problem. I see lots of U tubes about how to replace them. Its a simple thing. However, it makes me wonder why these relays must fail often. Maybe they can't handle the vibration the way they are attached to the frame. Have others experienced similar failure rates? I'm going to buy some replacements and make sure I have the tools on the boat so I can replace them on the water. I don't think that there is a problem with the cabling and connectors.
alldodge
First time it "might" be the relay. Having it happen twice it's most likely not the relay, might be the switch or the wire connections
Mc Tool
7 years ago ? Do you use the trim a lot ? ....I do .
Also it wouldnt hurt to make sure the trim motor is within spec.🙂.
Texasmark
corrosion?
cheap replacement?
Carry a couple spares on the boat.
Since the relays are sealed but the contact to the external wiring harness isn't, my guess is that in your replacement operation, you slid the relay contacts out of the sockets and slid the new ones in, both operations cleaning off the wiring harness contacts surfaces.
If you have the problem again, pull the relays out, squirt some solvent the oil in the contact area and reinsert the old relays right where they were. Maybe plug them and remove them several times then test. Check back!
I've had a 2002 90 and 115 Merc. for quite awhile and haven't had a problem with either......but I boat in fresh water...no salty, corrosive atmosphere.
boscoe99
See if you can find some solid state relays that have the current carrying capacity of the mechanical relays. Generally they have a much longer service life.
I suspect once you see the price of the solid state gizmo it might make sense to carry a spare mechanical relay.
I would investigate issues with wiring / trim motor.-----Replacing parts is not always the cheapest approach.
boscoe99
Easy enough to trouble shoot the relays. Swap the up and down relays. See if the problem moves from the failed side to the good side and vice versa.
dog22
I don't know if the engine is used in salt water or fresh water ? i have never replaced 1 of those relays in all my mercs they never go bad unless you have corrosion on the tilt and trin wiring and that will increase the resistance which will blow the relay but if you do service couple of times a year and keep everything in top shape those relays should last for the life of the outboard
