1988 johnson
Checked timing today with timing light at idle in the water. Marked flywheel at TDC for each cyl. When I pointed light at flywheel for cyl 1 I could see the mark for cyl 1 and 3. Same thing when I hooked the light up to cyl 2 I could see mark for 2 and 4. Seems like double fire, or maybe my timing light is not good enough to pick up each cyl seperately. Anyway the timing is not perfect. It has a miss at idle and the mark for each cylinder jumps over 5 degrees or so using the light. I read somewhere that this seems like pwr pack problem. Thing is I replaced ppack, stator, timer base, coils, and plugs. I wonder if I have faulty ignition components. I am about to get a DVA or peak reading meter and check voltage on coils, ppack, tbase, stator. Going crazy trying to diagnose this motor.
