Live-liner
- Sep 19, 2012
- 74
Hello,
Another stupid quesetion.....
1986 3.7 190, Trying to set timing, however the marks are not where they are supposed to be. What would cause this? I changed the keyway on the crankshaft a couple years ago, and have not been able to set the timing correctly since. The black mark on the picture is around wheer the mark is now. If I was off a tooth on the timing chain, would that have caused it? If so, couldn't I just find exact TDC on #1 and put a new mark on the balancer at 0. How would I find exact TDC? Usually I would do it with the mark..... Is there a gauge I could use in the spark plug hole?
Thanks
Thanks
