This 7.5 is really old. Out of the 70s I think.<br />The Mag for the thunderbolt ignition failed and is worth more than the motor. I threw away the mag and coils, and installed automotive coils and condensers, and plan to use it with a dead loss battery system.<br />I set the points very accurately with a dial indicator on the pistons, but the timing is obviously off because it fires so soon, that it stops me in mid pull. It used to start with about a 6" pull.<br />My question is; Should there a timing difference between a Thunderbolt ignition, and a condenser ignition? <br />Is 23.5 degrees too much for a points and condenser ignition?<br />Thanks
