ddbyrd3
- May 9, 2005
- 369
1981 140 Johnson J140TXCIM, I set the timing at 24* static, I backed the boat up into the water to verify under load and it was still 24*.<br /><br />The book says to allow the timer base to rest firmly against the stop regardless of RPM reading. (mine I believe, was @ 3500RPM)<br /><br />I thought the power packs were to make up the additional 4* to max at 28*.<br /><br />Is this a sign of bad power packs or do I need to set my timing to 28* initial?
