Timing specs 2006 15hp 2stroke
Maraian
Can anybody tell me What the timing should be at idle? Wot?
Can't seem to find this Info.
Is it measurable with timing light on this motor?
How did the motor run last season?---- Timing does not go out of adjustment.------If you have running issues then do some trouble shooting.--What is your motor doing / not doing ?----Or what happened if your motor quit ?--
Maraian
Won't idle. It was running good above idle until recently started missing and stumbling. Rebuilt the carb. It's got good spark and compression. Thermostat replaced end of last year. It's pumping water. Replaced water pump over winter. New plug wires. Grounds are good.
I doubt that timing is the issue.---Unless the flywheel key sheared.
