Timing tab deteriorated
theundercut
Not sure how to go about setting the timing as the tab is completely deteriorated. Any suggestions? 1989 four winns horizon. GM 4.3 with omc cobra outdrive.
EDIT- Can I find TDC and then mark the block/balancer then use a timing light with advance?
you can - use a piston stop, then paint a line on the timing cover. I would use a proper sized timing tape vs an advance light. however you have some serious rust on that damper, and the timing cover. it looks like a rust hole just about thru in the pic
I would pull the accessory drive off the motor and wire brush the rust, then get some paint and put a coat of paint on there.
theundercut
Sounds good, I was going to use a whistle as I have never used a piston stop. Are they more reliable? That isn't rusted through just the image. I inherited this boat am just trying to get it running smooth. Thanks!
If you want to find TDC accurately, you need a piston stop and degree wheel.
That is engine 101
theundercut
That is engine 101
I'm not familiar with a degree wheel. Can you point me to a resource on how to find TDC with a piston stop and degree wheel? I'm a shade tree mechanic and did not take engine 101.
