tmd
CROSSJCG
hypothedical question,say i did have a leak in the head gasket wouldnt it burn white smoke threw the exhaust like on a car,or steam?gonna run the boat tommorrow ill look and see if leaks around the gasket.theres alittle water at the bottom of the cowling is that typical?turned the idle up do i need to also adjust the pick up roller,it idles fine but when put in gear its alittle slugish or wants to stall,thanks jeff
The Marine Doctor
Re: tmd
A blown head gasket would prevent water from pumping though and cause an overheat.<--if severe enough.<br /><br />In a car..the WHITE you see is antifreeze burning.<br /><br />Do not worry about the throttle cam.<br /><br />TMD
