To Build a Boat (any boat)
cpj
Ensign
Re: To Build a Boat (any boat)
see, the problem is "floater" brings up some images that make us think of your Mr hankey problems!
CalicoKid
They're one in the same.. What did you think I was talking about? :D
CalicoKid
<br /><br />Like I said earlier, yard art. :D
CalicoKid
This morning was the ideal time to splash the dug, sunny with a breeze from the South. I decided it would be a good idea to try it out in one of the canals rather than the open bay considering a South wind would blow me away from shore on the bay if the dug couldn't be effectively handled. Good call. The dug was extremely tippy and had no tracking ability whatsoever. I'm a bit heavyhanded with a paddle as I'm used to pushing an 18.5 footer with a couple hundred pounds of gear and food. I had to change my approach with the dug as my first stroke very nearly capsized me and spun the canoe around backwards. There was no leaning over the sides and no healing over without the feeling the dug would slide right under the water. There are only a few inches freeboard and the gunwales touched the water with every stroke. Once I got the hang of getting the conoe to move with some foreward momentum it was kind of fun! I think it would make a neat beach toy where it wouldn't matter if I got wet or not but the water is under 50 degrees right now and I didn't feel like swimming. So I kept it short and called it a success. :D <br /><br />The design itself is a joke really and my building it was the punchline. It was a fun, easy project that I have around twenty bucks into thanks to some innovations (or shortcuts if you like). It is a boat or a canoe only by the most general definitions. It is very narrow and flat bottomed for maximum instability. It has too little freeboard thanks to its width and the fact that only ten feet of it's length are contributing to displacement. The long points were good at getting in the way. Since the canoe 'felt' like a ten footer I was pretty unaware of the extra eight feet, mostly in the stern, and caught it on shore a few times while turning, which was almost always since it would hardly go straight. The points also made launching lengthwise impractical because the bow would just go underwater, so I had to set it in parallel to shore. On the upside, with such low freeboard and the downturned ends the wind had nothing to catch other than me, so windage is good!<br /><br />As for my choice in materials I think I did fine. There is no need for strength here as the boat as a whole is not capable of hauling gear, taking waves, rapids, or heavy handed paddling. I see no reason to build it any stronger.
Wimperdink
that is awesome... ok quick question... ya think two of them with the tops covered would make a decent light weight poor mans pontoon with a small motor? would a small fin under the stern make it track straighter or work better when using it as a pontoon? or is it basically useless as a boat? Also I saw in the pictures of them that others built that one person put a single outrigger on his for stability and said it tracked way straighter... whatta ya think?<br /><br />p.s. wimps chat is open
CalicoKid
I don't know about the dug as a pontoon, it doesn't displace much.<br /><br />
Wimperdink
I think with two of them about 2 feet apart and enough thrust it should plane looking at the slope of the keel. great lil one man toy :D and with two sheets of ply and some extra parts and a lil ingenuity would be fun.
CalicoKid
I doubt it would be good for planing with an outboard. You could maybe make a raft and push it around with a stick.<br /><br />
<br /><br />My wife said it looked like one of the dried leaves blowing around on the water.
Wimperdink
thats got a cool shape to it in that last pic didnt realize the points were that high off the water
JasonB
This thread has to be in the top 5 list for most pages/posts.<br /><br />*shameless bump by one more post*
Pony
I like the looks of it calico, how hard would it be to make the sides a little higher?
CalicoKid
Well Pony this boat is a one sheet design. I used a single 4x8 sheet of luan. The only wood leftover after cutting the pieces was sawdust, and I even mixed a little of that into my resin. If one wanted to go ouside the one sheet restriction and buy more wood then I suppose you could make the boat higher and wider too. (I added the gunwales and thwarts to mine.)<br /><br />If you haven't already check out this site on simlpe boatbuilding: Hannu's Boatyard; Check out the one sheet boats and you'll see the limited options available within the one sheet limit. The Dug is in there as well as some floating box type boats and a few round ended boats that I'm thinking I could use as a next project. I chose the Dug so I could practice and make mistakes without involving a lot of cash and time.<br /><br />I wanted to start with something very basic for a first boat and hopefully not become discouraged and never build a boat at all. I based my success on whether or not I finished it at all. Now I'm ready to try something a little more complicated and twice as expensive, which means around fifty bucks. I'd like to build a Sneakbox afterwards and see where that takes me.
Wimperdink
Originally posted by CalicoKid:<br /> I'd like to build a Sneakbox afterwards and see where that takes me.
I cant wait to see that one in build phase i've been looking at that one for awhile now but decided to wait till I have a motor worthy of putting on it... i'd like to see that one on my trailer with a 25 or 30 hp on it. :)
CalicoKid
A five to ten would be more than enough. Your weedless might be a good one! That's a little boat Wimper! Narrower than your Minimax and only a few feet longer.
Wimperdink
I went back and looked at it and I didnt realize how small that thing is... still looks like fun though and i'd still want more than my 4 hp on it. :D
cpj
Ensign
this is a high jack go to my yak by cpj. i need to catch up with dink in number of posts. right now hes 10 pages ahead. :D :p :D
Pony
this must be the latest high jack attempt ever
CalicoKid
lol! When are you going to hijack it pony? Page fifteen?
CalicoKid
That's allright, Wimper will hijack it back, he's full of ideas :D
