toggle switch / amps ?
gcboat
I need a three way momentary toggle switch for the engine trim. It's a strange setup but I have a switch on the throttle control and a secondary one on the dash. The dash switch is toast - now neither works!
So, did some looking and found a 25 amp unit that appears to have the function I need. Am I heading in the right direction?
Could get zero info off of the old switch. It's for an outboard motor.
tashasdaddy
Re: toggle switch / amps ?
i use a 20 amp on off on toggle for trim switches, never had a problem, so you will be good with a 25 amp.
