AKA Mercury 3.5M. I recently came by a couple of these motors in which the shift handles, shift shaft lever, are frozen in place. I removed the lower unit to find the the lowers in working order for the most part.. I then removed the powerhead on one of them. I soaked and heated the shift shaft handle rod as the plastic handle was long gone, broken off,probably from trying to force the motor to shift as it became more and more frozen in place.I see that the shift shaft lever Tohatsu part # 3AB661300 is available to purchase as listed in the parts diagram I have been looking at. The problem I am having is removing the old one. It took a lot of heat and penetrant to get the thing to move in the first place. I figured at that point it should slide out. Not the case. I dont want to beat it as I will flare the ends. The heat has likely melted any O rings inside of the Gearcase driveshaft housing. I would think the shift shaft lever would slide out at this point, but not the case. I thought it may have been heat pressed into place but if so the O rings would not have withstood the heat upon the initial installation. So I am baffled. Before I start to pound it does any person have any suggestions as to how to replace the Shift Shaft Lever. Thank you for reading my post.
