Re: too big!
wrong... you don't need escorts in any state I've ever been in at 10 or even 12 feet. Most states have exceptions for recreational boaters also BUT and this is a big BUT.... The O/P didn't ask about anything resembling a wide load....
A 23 or 24'er is NOT AT ALL too big to trailer... I launch and load my 28'er 10' wide every bit as smoothly as any lil ski boat... It is a non issue.
The OP actually asked two questions.
The specific question, "Is a 24ft Searay too big? "
I agree. It is very doable with the proper equipment and mindset.
And, the very general question, "What would be considered Too Big to Tow."
Once he found that the 24footer was not an issue, he would logically be wondering, "What are the limits."
30ft, 60ft, 90ft?
And, I will agree right here that this is likely getting out of the limits that most people might consider, but that is what usually happens in forums.
The entertainment and educational value of the side stuff is not to be dismissed.
What is too big to tow has to consider Length, width, height, weight and logistics.
The OP doesn?t identify his state as far as I can find.
So looking at a few states of interest, Indiana and Ohio.
Indiana requires permits if over 8"6 or 60' length
Pilot Cars needed at 12'4" wide ... or over 60' in length in some situations.
Weekday, Daylight travel only. If over 10' wide weekends are limited to Saturday before 12 noon.
Ohio
If over 12' wide travel is limited to daylight, except not during rush hours,
Escorts need at 13' wide
If over 14' wide travel is limited to 9am to 3pm, Tuesday thru Thursday only.
Weight at 80,000 lbs will likely not come into play.
But 13'6" heights may.
The point of all this side discussion is that depending on your state, width will become the limiting factor before length, and towing may be an issue at 10 ft wide if you want to go to the lake on a Saturday afternoon.
Now, let's consider the issues with the city and keeping a 30 footer in your driveway....
