Re: Too much compression?
Oh, this is interesting.
OP says, engine makes a noise, limps back to the dock. Bilge is filled with oil, dip stick blown out. Boat repair place sez he needs a new engine.
Im thinking a big hole in the piston , at the least.
But the compression readings seem to be right, no more engine noise. Runs good at home on the muffs and as far as over revving at home? I would have done the same thing, thinking I would force an issue and would rather have it break in my driveway instead in the water somewhere where you cant walk home.
Im still baffled? Think I would splash into the water, stick close to the ramp and run it as hard as you can to see what happens next.
Engines under a load act a lot different then in the driveway with muffs on.
Interested in your results.
