Top speed too low?
nola mike
Still seems low.I don't think I should have almost 10 mph on you with the same hp. Any idea of the weight of the boat?
Chuckles88
It made no difference in top end with 450 extra pounds. I also checked the foam in the hull and it was dry in both sides.
nola mike
I found a great site that listed specs for all the late '80s glastrons, from glastron, including fuel use, top end, 0-30, etc. Can't believe I can't find it now . Mine had a listed top speed of 50 mph, and I'm still within 3mph, 1700#. I still think you should be mid 40's easy, but who knows I guess
achris
More fish than mountain goat
.... My estimations have me thinking I could go to a 14.5 x 19 to get me right in the middle of the 4400-4800 and bring my top end up a bit. Does this sound correct? Thanks!
No, stay at the top of the range. 19" will take you down to the bottom end, and that's a BAD place to be (each inch of pitch is worth about 200rpm)....
I'm currently running a 17", and I get a tad of 5000, 19" puts me right in the middle of the range at 4600, but my acceleration suffers, the boat feels 'heavier', and I have no increase in top speed. Where I am now (and where you are) the engine isn't working as hard, so less wear, and it's more 'driveable'...
Chris......
scoflaw
Ensign
I prop for midrange, where I spend 90% of my cruising. WOT and holeshot are not important to me. The difference may be 5 mph at 3200 rpm between the 17 and 19 in favor of the 19
achris
It's not about having great holeshot and WOT speed. It's about not making your engine work so hard. Think driving around a gear too high all day... Your engine will not love you for that!
Chuckles88
Thanks for the replies. I'll stick with the 17 and see if someone can lend me a 19. I might just have a tired engine.
at 5000', your down 15% in power than you would be at sea level. (no getting around that unless you have a turbo or supercharger)
so if you were at 185hp, you are now at 157hp, and your top speed is about right
nola mike
That was what I was wondering earlier... And he should be at 175hp with his year, right?
Chuckles88
It is a 175hp. I saw the sticker on the valve cover. I'm dreading a compression test but It needs done just in case. The prop is a little chewed up so that will be first.
Well, if the OP was at 175 and at 5000' his power is closer to 147 hp then. And his speed matches what i would expect
achris
And it's a 29 year old engine, so it's probably lost a pony or 3 over the years. Possibly down to around 130 now?
Chris....
nola mike
Yeah, probably not that far off with those factors. I only hit 40 today @ 4100rpm wot, though with 1200# of passengers fwiw. Fatasses make a big difference.
Chuckles88
Haha. I guess I'm lucky with weight only dropping mine down 2-3 mph. I shouldn't complain with a 30 year old engine. It pulls hard and plains in about 3 seconds
Rick Stephens
I'm in the uglier part. Pocatello, but it's still Idaho.
My kid is a freshmen at ISU. I loved the visit down there at registration. Was thinking of dragging the boat down when the wife and I visit. There's an upcoming parent invited event in 5-6 weeks or so from now. Any fishing to be had?
Chuckles88
This time of year a lot of great river fishing. The reservoirs are getting pretty low for the boats.
