Topic participation indicator?
Boomyal
Isn't there supposed to be some kind of indicator mark, on or around the little file folder at the beginning of a thread topic, that denotes that you are a participant in that thread?
Furthermore, I also thought that if you participated in any thread, whether you initiated it or not, that you would get one of those little red notification boxes flashing when someone posted after you?
GA_Boater
The posted to a thread indicator got smooshed in the upgrade. It's being worked on with VB as I understand. Apparently it isn't an easy fix.
On your notifications, I think it is all in how you set those up in your profile. I don't use the feature and rely on my faulty memory, so maybe a member who does use it will chime in.
alldodge
I don't see any indicators anymore. You get auto notified if you start a thread, but have to select subscribe at the top for each thread you want to be notified. The subscribe button changes from +subscribe to (check mark)subscribed and color change
