- May 29, 2003
- 19,241
If after adding the Freon the system still doesn't seem to be cooling properly, you could have a plugged expansion valve. And before getting too excited, those things are really cheap and mostly plastic thin little sections about 5" or 6" long that fits inside the tubes. I've replaced them before for less then a few dollars. BUT, you have to break open the system to get to it because it is usually in the evaporator that is inside the vehicle. How it works is the Freon entering the evaporator has to flow through the expansion valve and that allows the Freon to expand and that sucks the heat to accomplish that. Then the fan blows across the radiator like evaporator and you get cold air coming out. And if there is any contaminates in the system, the expansion valve gets plugged up and restricts the Freon flow because of the very fine screen used in them. I've seen them totally covered in black particles where they couldn't pass anything though them anymore...So just a little info...
Understand that it is a CLOSED system, so if the expansion valve is plugged, it is probably because the desicant (sp?) bag has broken, or a seal is disintegrating. In other words, you have other issues going on. Unless you are an A/C specialist, you might want to have a professional look at it. Home fixes will only prolong the inevitable for so long ...
