Torque spec for Caulkin 5 bolt Rim
leelgert
What is the Torque spec for Caulkin 5 bolt Rim 13" wheel, It is bolt type not nuts.
H20Rat
90 to 100 is generally considered the MAX before you start deforming the stud, the actual torque depends on the wheel type. Steel wheels deform more than alloy and require lower torque.
I'd shoot for around 75 ft/lb's.
leelgert
thanks for all the input, gives me a ballpark figure to start. I will just check and retorque more often. Great forum.
bruceb58
Make sure you don't lube them if you are using that torque. That's a dry spec torque.
