Towing 17 ft w/ a 1999 Jeep Grand Cherokee?
MajBach
Re: Towing 17 ft w/ a 1999 Jeep Grand Cherokee?
Dave: The ABS, parts of the A/C and parts of the rad all occupy a spot near the front of the driver's side. Yes, Canadian $$$. Actually, 'those' expensive little cars - built in Ohio - are typically cheaper to fix than any of the big three doemstics. Randomlly select some parts and price them out if you dont believe me. <br />Regardless, everyone is greasing someone else's hand in the autoboady/insurance underwriting business so whose to say what it REALLY costs.
jlinder
Majbach,<br /><br />You tow with a vehicle that is under rated, without brakes when you should have them (need them by law?). You have had no problems and have been doing this for a long time.<br /><br />My father-in-law has been smoking 2-3 packs a day for 60 years. I know of a person who died in a car crash because he was wearing a seatbelt.<br /><br />The point is that there are always exceptions to the rule. You seem to be it. I am happy for you , really. I hope your good fortunes continue.<br /><br />You say
but there is no substituting for experience
I agree. But I want to go with the experience of the tens of thousands out there with experience and engineering knowledge that disagree with you.<br /><br />Regarding the question of whether or not your car will suffer damage from being overloaded that is not my business. <br /><br />But the question of safety becomes my concern because you and I (or others like me) share the same roads. One day you may go from being the exception to the norm, and on that day your decisions may cost someone else dearly.<br /><br />Please do not misunderstand. I do not wish you any harm or troubles. I hope your boating experiences are all good and fun. But gambling with your safety is gambling with the safety of others on the road, and that concerns all of us.
BillP
The jeep should be able to tow that rig without a problem. Even without a tow pkg unless you are doing mountains.
MajBach
Jack: I appreciate your comments and understand your position.<br />Simply put, my original post was intended to state that [my] car can stop [my] boat in an adequate distance.<br />Not to come off as presumptuous, I have done some research into this matter as well from another thread with my input regarding passenger tires on a trailer. It also might be relevant that I am in the final stages of training to be a Conservation Officer. Part of my duties will be to inspect vehicle/trailer combinations.<br />After reading the Highway Traffic Act, consulting with two of my instructors - one of which teaches a course on trailering, and a couple of calls to the Ministry of Transportation, this is what is conclusive and therefore legal:<br />my car is not underated for pulling my trailer (although the trailer MAY be underated for the load it carries - that hasnt been determined), the trailer does not require brakes, and there is no regulation stating that trailer tires must be installed on a trailer - passenger tires are fine. There is a law stipulating the trailer tires cannot be used on cars however.<br />On that last point of trailer tires. The authority I inquired stated (who happens to be an inspector for the MTO) that he uses passenger tires on all his trailers.
BillP
more 02 cents...A 3000lb (2850lb) Accord pulling 2300lbs will jacknife easily if you hit the brakes hard on wet pavement at 30mph. It happened to me with a 4300lb Towncar pulling 1500lbs at 30 mph. Trailer brakes would have prevented it. <br /><br />Using car tires on a trailer only opens the door for liability and negligence if you get into an accident. Beyond required tire laws, a lawyer will go after you for not meeting a "reasonable" standard. The jury is going to look at you hard for causing an accident and not having the proper equipment. <br /><br />But anyway, towing heavy loads beats up any and all vehicles. Jap cars are tough but not indestructable. Having 225k miles on the original Accord clutch and rotors only tells me it has very little trailer towing time. I've owned a few jap cars and my daughters currently have a 200k+ mile Civic and a 100k+ mile Celica. Parts for them are outrageously high, even when compared to Lincoln Towncars.
MajBach
Hi Bill. Jacknife? Nope. <br />I should clarify how I ended up pulling this boat with this car becasue I get the impression that most people here assume I am being irresponsible or negligent. First of all, I am a commercial pilot - or was. My point being that I err on the side of safety or caution. And, as preveously stated, I will soon be a law enforcement officer (airborne with any luck). It would be hippocrital of me not to practice what I enforce.<br /><br />When I bought this boat, I owned a Prelude. While the car was as powerful as the Accord and only a few pounds less, the only available hitch for it would was rated to low for what I would be towing. <br />Before I purchased the Accord, I spoke to a well-trusted mechanic and a couple of 'boat people' I also trusted to give me an objective and educated opinion, and all agreed that while being heavy on the car, it would not be unsafe. I chose a car over say a truck because I had to consider the fact that I would be using it as a primary vehicle and most of the time this would not involve towing. I kept the boat in a slip for the first season until I could find a 2-door accord with ABS, 4 wheel disc and manual transmission - all for the purpose of being benefital for towing.<br /><br />The first few times I towed the boat was with a friend's chevy full-size pick-up. After towing the boat for the first time with the Accord, I was surprised at how little difference there was between it and the truck insofar as how it pulled the boat.<br />The first thing I did before towing on busy highways or amongst traffic was take the car/boat out to some back roads and drive it under different conditions: pavement/gravel and wet/dry. I also experimented with emergency maneuvering and full braking just to ascertain what the car was capable of and what it wasn't and to avoid any surprises in real life situations. Perhaps it's becasue of the ABS but regardless of gravel, pavement wet or dry, the car will not jackknife when the brakes are fully applied - even in a slight turn. I can certainly stop faster and safer than any dump truck or tractor/trailer combo not to mention emergency avoidance.<br /><br />I disagree with you on the legal aspect of having passenger tires on a trailer based upon the people I have spoken to recently.<br /><br /><br />I would also submit that you are unaware of just how rugged at least my car in particular is. I just did some quick calculations and based on a round trip distance of 244 miles to where I typically trailer to at least 12 weekends a season, thats approx 3000 miles/year for the last 5 years. AS I said, I think that's a conservative estimate. You can decide if you think that's low. MYself, I am impressed at how well this car has done.<br /><br />Interesting that you find the parts for these cars are high by comparison to domestics. My experience has been the complete opposite except for a Tercel my wife used to own. I guess it doesn't matter much though when one hardly ever needs to buy parts.
BillP
I'm a pilot and previously owned two airplanes. It has nothing to do with safe towing. Erring on the side of safety in this case would be having a large heavy tow vehicle w/tow pkg and brakes on the trailer. <br /><br />I'm sure YOUR Accord is special but the trailer doesn't know it. That weight combination can break loose the rear wheels of any car during a diversion attempt under hard breaking, especially when wet. The tail can easily wag the dog here. If it matters, I currently tow 1800lb & 3000lb boat rigs with a 4300lb Towncar touring sedan series...airshocks, performance suspension, larger tires and ABS. I have 10s of 1000s of tow miles in the last 20-25 yrs up to 4500lbs behind vehicles that dwarf Accords. Please don't try to tell me your 3000lb Accord won't get sideways when my 4300lb tcar will. My tcar eats Hondas for lunch <grin>.
Johnshan1
All I can say is WOW. Would not want to tow that boat with that car.....
MajBach
obviously this is never going to reach agreement. All I can say is been there, done that, didn't happen the way you say it would.
Lou C
Well I'll tell you what, why don't you look in your Honda owner's manual and I'll bet you that they require brakes on any trailer over a very light one (probably anything more than 1000 lbs). So if the car manufacturer, who designed and built and tested the car (the gov't agency that makes trailer laws does not know what you are towing with) says IT NEEDS BRAKES,to me this supercedes what the local statue is, based on common sense. <br />If the Honda weighs 3000, and the boat weighs 2300, did Honda design in brakes to stop 5300 lbs(more if the Honda is loaded, more like close to 6000), way over the cars max gross weight? I don't think so. So even if what you are doing it techically legal, if there was an accident, I wonder if some lawyer realized, well, the car is not rated to stop that much, the car manufacturer says clearly to PUT BRAKES on the trailer, and the owner, can he be seen as liable?? <br />My old 98 Jeep, which weighs about 3800 lbs stripped, can carry 1130 lbs payload, and is rated to tow 5000 lbs. But trailer brakes are required for any trailer over 2000 lbs, according to ChryCo.
craze1cars
Legal? Illegal? Smart? Whatever. IMO Lou has the best point when he brings up the lawyers. If/when this towing combination causes an accident, contributes to the severity of an accident, or is INTERPRETED IN COURT to have done either of the aforementioned items...that's when the lawyers will eat you alive. Despite your careful consideration, "special" car, and high level of training, I sincerely hope you have a very sizable liability insurance policy because you're definitely risking the financial future of yourself and your family IF something should happen. It'll be real easy to find a WHOLE bunch of sources and people and experts who will testify that your car is undersized for the job you're asking it to do. And it will be very difficult to find anyone but yourself to try to defend the setup as being safe. Therefore you will lose a civil case real quick if if ever came to that. And I sincerely hope you never find out the hard way...
MajBach
I think you and Lou are enganging in pure speculation and haven't the slightest clue what you are talking about!<br />You'll remember an insurance company [Canada's laegest]and underwriter already shelled out the better part of $6000 to cover me in an accident in which there was no second party.<br />No judge or JP could ever find me faulty for operating within the confines of the law!
Johnshan1
What's the tow rating on a 1996 Honda accord?
Lou C
Maybe lawyers operate differently in Canada than they do in the US.<br />Here my points would be anything BUT pure speculation. A smart atty would check to see if your trailer was required to have brakes, if not, probably would then see if the car was under rated or recommended to have brakes by the vehicle manufacturer. <br />No one was injured in your accident, all they were paying for was property damage. Once someone gets hurt all the rules change, at least here. Then you have medical payments, pain and suffering, etc, etc. Your accident had nothing to do with whether you could stop fast or not. You got hit by a bouncing tire. If you hit someone because your Honda was not designed to stop over 5K lbs, and someone was injured, whole different story. Maybe law is practiced more reasonably in Canada than here.<br />To give you an idea, if you want to put bigger tires on your 4x4 and go over to Sears, or Discount tire, or whoever, they will NOT do it, because of the Ford/Firestone/Explorer lawsuits, they will not put a tire on that was not listed by the manufacturer as OE, period. U-Haul will still not rent trailers to people driving Explorers, even the new gen ones, that are totally differnt than the older models. <br />I can tell you that with my Jeep the trailer brakes made a HUGE difference in the ability to stop fast. Even though they are a maintenance issue in salt water areas like mine, I would never go without them.
MajBach
Point taken, Lou.
craze1cars
Last time on my soapbox and I'm gone from this thread since we're WAY off topic. <br /><br />Believe me, I'm not speculating. I am an insurance claim adjuster. And my comments have absolutely nothing to do with first party/one car accident claims (for example your bouncing tire claim...bouncing tires don't hire lawyers, people do). My comments were referring to third party claims and civil suits. I have sat in more than one courtroom where people have been found legally liable in an accident because of things like failure to secure a load properly, failure to maintain their vehicle in safe operating condition, and TWICE I have personally seen people found at least partially liable in an accident because of overloading their vehicle beyond its capacity. <br /><br />Here's one example that I remember clearly from about 10 years ago: In this case the overload increased the severity of an accident, theoretically making a bad injury worse. Even though the accident was not even the fault of the person who had overloaded the vehicle, they were found 50% at fault for the injury becuase their overloaded vehicle could have stopped/slowed down to a greater degree than it did had the vehicle not been loaded beyond its capacity. So even though the other driver in the car had illegally pulled right out in front of an overloaded truck that was running 60 mph, experts proved the car got T-boned at 35 mph instead of 15 mph, which would have been the speed of the overloaded truck had it been loaded within its rated limits. The difference between getting T-boned at 35 vs 15 was proven by doctors to be the difference between paralysis and a broken arm. So the overloaded truck was found 50% responsible for putting someone in a wheelchair forever and had to pay to put that persons family through college, etc. The lawyers for the paralyzed person in the car brought in experts from Chevrolet to make statements regarding carrying capacity of the Chevy truck, etc to help prove their case. In this case there was no trailer, it was a 1/2 ton pickup with a full load of sand in its 8 foot bed. I believe the weight of the sand was about 3x the rated payload of the truck. If this were you in that courtrom, the lawyers against you will likely bring in experts from Honda to discuss the towing capacity of an Accord.<br /><br />I'll carry this a little farther (and absolutely this short paragraph this is PURE speculation)...a sharp judge/jury might just find and pull your threads/comments from this very I-boats forum to prove that you were well aware of your vehicle being overloaded, yet you didn't heed the advice of other people here who warned you in advance that your setup might be unsafe.<br /><br />You need to recognize that where written laws leave holes in the law, a civil judge/jury will fill in the blanks with their interpretation of "reasonable and prudent person" arguments. In your case an attorney would argue that no "reasonable and prudent person" would think that a vehicle that Honda places a 1,000 lb tow rating on could safely handle a 3,000 lb boat. Mark my words, you will get quickly chewed up and spit out in court if your overloaded Accord ever gets mentioned, even possibly in an accident that is not your fault. <br /><br />I, too, am talking about United States civil lawsuits. Canada may be different but I believe our courts are very similar....and the odds of such a thing happening to you I'm sure are very very small. Regardless I would never consider risking the financial welfare of my family in this manner. <br /><br />On a somewhat related note, I see absolutely no point in your towing setup. Why the heck don't you just buy a proper tow vehicle?
Johnshan1
So what is the tow rating of a '96 Honda Accord?
BillP
Oversized towing load. Car tires on a trailer. Someone gets hurt. It's a lawyers dream. Get the checkbook out. If you don't have enough insurance to settle they can and will sue for your personal assets. Unfortuately it's reality. Lawyers leave no rock unturned when it comes to big paychecks.
Johnshan1
2000 lbs rating for a '96 Honda Accord I bet....
