Hi All, had a question regarding towing capacity... Considering buying my first boat and have a few models in mind and have kicked a few tires lately on a few of the nicer ones. Went out to see a 99 Sylvan Expedition 1600 today with a 50hp merc 4 stroke and I really like it. I checked into the all up weight, and it looks like the boat is 850lbs, motor is 250lbs, trailer is 300lbs. A full 60l tank of fuel and some gear would add another 120lbs or so which takes me up to 1520lbs total weight.
My vehicle is a 2003 Honda CRV with a 5 speed manual.... the book says I have a 1500lb towing limit and this combination is right on the top of the range. Fuel and gear can be removed to bring the tow load a little under the limit, but I have to wonder if Im asking for trouble here? Will the vehicle be able to pull this load up a boat ramp? Am I risking clutch problems pulling so close to the max load on an almost 10 year old car?
Will this be OK, or should I be revising my target boat to reduce the overall weight and add a larger safety margin?
Thanks... Jon
Thanks... Jon
