Towing
Wild b
I have a dodge 1500 v6 with 2500 lbs helper springs I just bought a 25 ft baja with big block will I have a problem pulling it out of the ramp between trailer and boat it weighs about 5000lbs,I hope I didn't put the cart in front of the horse
SilverSS07
Re: Towing
4wd or 2wd? What year truck? What gears in the truck? Limited slip? Is that the boat's weight dry or loaded with fuel and stuff? I don't think the V6 will be too happy pulling it around but it should do it. Put a big trans cooler on it. I just looked up the towing capacity on a new v6 ram scsb and it's max is 3750 so I'd say it's time to look for a new truck.
Oshkosh1
Ensign
Re: Towing
Unless the ramp is in REALLY poor shape...No, you won't have a problem actually getting it out of the water. Now as for actually towing it? I wouldn't have a problem towing locally...just don't plan on going more than a few miles.
444
Re: Towing
You will be fine towing with it and at the ramp you should be okay. Just keep the back tires on the pavement and try not to let yourself spin the tires at the ramp. Not usually a problem unless it's algae covered. Not a ton of difference between the V6 and V8 powered dodge half tons other than power so you should be able to get by. Those V6's are kinda doggy at best so your highway performance will suck. Even my buddy's 97 ram 5.2 feels my 2000-2500lb boat/trailer behind it so your v6 is not going to be the greatest thing for doing a lot of highway hauling.
brewern
Re: Towing
Do you know if the foam is wet under the deck? If so, that'll add a ton of weight.
Wild b
Re: Towing
Thanks,4 info I live in Tampa won't be making any trips to far.
brewern
Re: Towing
Can anyone here recommend something other that ripping up the deck?
What if we drill a hole down about 6 inches, then insert a plastic tube and apply a vacuum. Seems that would tell us if there is water in the foam.
I'm just shooting form the hip though. Let's see what the pros say.
Wild b
Re: Towing
The foam is almost impossible to keep totally dry it's what keeps the water from sloshing around to the back of the boat just will try to keep the bow from diving into any waves at low speed.
brewern
Re: Towing
Check out some of the restoration threads. It amazes me how much water the foam can hold. If you can drain that out, your boat will literally be a ton lighter.
Wild b
Re: Towing
Truck has limited slip,trans cooler not quite sure what gears are in it
LippCJ7
Re: Towing
Wild b, I have a similar sized boat and twice the truck and even I spin occasionally at the ramp, I think you will be fine for awhile but you certainly need to upgrade vehicles before too long, your truck just isn't big enough for that boat and no upgrades will be enough, you need a 3/4 ton truck for that boat or a heavy SUV, another thing to think about is wheelbase, the longer the truck the easier things will be at highway speeds, just food for thought.
Wild b
Re: Towing
Yea definitely looking to get a 2500 in next couple of months thanks for your your info
Re: Towing
Yes you will be happier with a 2500 4x4, preferably diesel but a gasser will do it.
