seanymph85
- Nov 5, 2013
- 199
While moving my boat forward so it sits on the trailer more the way it should I have discovered that the swivel style bolster bracket that previously would have been around 6" or more from the end of the bunk would now be located almost to the end of the bunk board itself. Approximately 1.5-2 1/2 max. from the end. I don't know what is the minimum suggested distance from end of bb to attach a swivel bolster bracket. Especially on the transom end of the boat with a motor on it. Right now the transom is approximately 2" past the end cross brace where rear swivel bolsters would be mounted.
So I either take the one end of bunk board and extend it more past the end of the transom so I can mount the swivel part of the bolster bracket further from the end of the bunk or I add another brace forward of the end of the trailer cross brace and mount the swivel bolsters further from the end of the bunk board that way. However doing so would place it closer to the forward cross brace where the other set of swivel bolster brackets would be mounted.
The latter option more time consuming, costly and difficult but I do not know how many feet of the bunk board at a minimum needs to support the bottom of the boat near the strakes. he boat itself is an aluminum V-hull that weighs under 200lbs according to online specs and measures approximately 13.5' in overall length
Any suggestions or insight on this concern would be appreciated as the new bolster brackets should arrive today. As well can anyone suggest if I need to cut out the carpet around the spot the swivel boltster will be attached and I assume the longest lag bolt of the appropriate diameter is used to fasten the swivel to the side of in this case 2 x 4 boards.
