Trailer Design Guidelines
bruceb58
Re: Trailer Design Guidelines
Man, I wish i knew that. What can possibly happen with it being too small? It may not brake right? Just so I know what to look out for, so I don't overlook any signs. Thanks Bruce
I am not sure of the design parameters. You would probably want to contact Titan. I am sure they use different master cylinders. One thing for sure is the piece that the ball connects to is a lot smaller than the one on the 10,000# unit so the capacity of the coupler itself, not counting brakes, may not be big enough.
rwidman
If your axle is too small, it may fail under load. Then the load will all be on the other axle which may fail.
The most common boat trailer axles have a capacity of 3500 lb each. There are some with higher capacities and some lower.
gozierdt
Well, one thing is in your favor. The data from the coupler states that it is sized for a 2 5/16 ball. That's the size you'll need to pull this kind of load. And four wheel brakes would be required in most states. As the other poster stated, you can call Dico/Titan, but I'm pretty sure they will stand firm that if you're over 7500 lb GVWR, you need the 10,000 lb actuator. Since you haven't ever used your unit, you might ask if they'd give you a break on the price of a 10k unit if you return the smaller one.
3500 lb axles are not expensive, I've seen them under $150 with the brake flange and both hubs. But you'll be looking at more for 5200 or 6000 lb axles. I strongly recommend disc brakes- they're about $300/axle with cad plating. Make sure whatever you order has the same bolt pattern as your wheels. You have 6 lug wheels from the pictures, you'll need to determine the bolt circle diameter.
One last thought. If you're going to all the work to replace both axles, you should consider mounting both of them to an angle frame that can slide along the trailer side rails to adjust the tongue weight, then be bolted to the side rails.
