- Mar 8, 2009
- 44,312
Re: Trailer Keel Roller, Need Help
I don't see anything wrong with the rollers in the pics, couple nicks but nothing a straight rod wouldn't straighten up. You boat is too heavy for the trailer you have it on, this is way your bending the rollers. Your trailer is a one size make fit all sort of thing, adjustable. My cruiser came with a heavy but junk adjustable type and would not support the boat correctly. I redid it and am still fine tuning it. My Rinker trailer is a well made trailer with fixed 2x6 bunks and the keel rollers are about 2 inches away from the keel when loaded. Go look at any boat dealer and the trailers setup.
A bunk trailer uses keel rollers to protect the keel when loading and unloading. A keel roller trailer does use keel rollers to support most all the weight of the boat but also use many more rollers to accomplish this. They would use several keel rollers spaced close together or multiples which would resemble the one pic Frank has.Boston Whaler has a little bit of an explanation in the below link.
Boston Whaler | Choose the Correct Trailer
Pic of old junk rollers..... View attachment 220942
