Re: Trailer Maintenance items
winch strap, inspect and replace if necessary. a winch strap can do a lot of damage if it breaks. seems like 100 years ago, i had one snap, and break the back window of a station wagon.
YUP! Plus:
1. Wheel bearings. Take them apart and evaluate the condition. If OK, repack and re-install with
NEW seals. If not, you get the picture.
2. If the trailer has brakes, bleed the old brake fluid out and replace.
Check the adjustment of the shoes (if drum). Most discs self adjust.
3. Lights. Do they all work? If not-WHY? Find out and repair.
4. Spare. Does it hold air?
5. Rollers and bunks? How do they look? If you have rollers, make sure all the retaining pins are in place. A roller going amiss will tear up the bottom of your hull in a hurry.
6. Tires. Look for weather checking and uneven wear. Pressure?
7. Winch. Strap and or cable/rope. If it's old REPLACE IT. Lube the gears with a lithium waterproof grease.
8. Fasteners. Make sure all bolts are tight and are not corroded. If they are, replace them-cheap insurance.
