- Apr 17, 2002
- 71,415
Re: Trailer Tire smoked and froze up
I'd use Kerosene, or Diesel,....... They're Alot Less Flamable.........<br />Also, is gasoline OK to soak bearings, and nuts from the tires in?
The Bearing,+ the Hub,+ Everything Else Should just Slide Off the Quill........<br /><br />I'd say that the Bearing is Probably Siezed to the Axle(Quill)..........Bearing is not seized to the race, the opening on either side of the race have a slightly smaller diameter than the bearing can fit through without damaging.
No,........ Grab the Hub,+ Pull.........<br /><br />Once the Nut has been Removed,.........<br />The Complete Hub Assembley is Supposed to be Free,+ Removeable..........<br /><br />Yank the damn thing Off...........So... I should drift punch out the race piece, can get bearing out?
