trailer wheels
tbird175
Will someone please explain what the j designates in wheel size nomenclature. (i.e. 14X6j) Is this type wheel suitable for boat trailer use?
ebry710
Ensign
Re: trailer wheels
tbird, welcome to iboats.
I give up in trying to figure out the j rating. Doing a goggle search I found solid trailer tires and rims both with that 14x6j designation. I have also found that the j is either a load rating equivalent to an 18 ply tire or a rating meaning not to exceed 100 km/hr.
If I were guessing I would think this tire is a solid core tire with a 100 km/hr rating for a cart trailer. But that is a guess based on one I found for sell. Someone will know more then me. My next thread show you what I a use to in trailer tires.
ebry710
Ensign
Re: trailer wheels
Look for a front code like "ST" to designate trailer tire.
"An optional letter (or letters) indicating the intended use or vehicle class for the tire:
* P: Passenger Car
* LT: Light Truck
* ST: Special Trailer
* T: Temporary (restricted usage for "Space-Saver" spare wheels)
example ST205/75R15"
http://en.wikipedia.org/wiki/Tire_code
Silvertip
Re: trailer wheels
There is another thread here asking the same question. The J is the specification for the bead area of the wheel. There are many designations but J is the common wheel spec for vehicle and trailer tires. And yes -- trailer wheels may also be marked with a J. 14x6J merely means its a 14 inch wheel that accepts 14 inch tires, it is six inches in width and the J is the bead area spec for the wheel.
