Transducer compatibility Lowrance and Humminbird
lmuss53
The left side is a Lowrance Elite 7, right side is Humminbird 798 ci HD SI, will these two get along so I can use them at the same time, one on regular sonar and the other on side scan?
lmuss53
I think I already know part of the answer, the H'bird needs to be below the Lowrance for the side scan to work. Is any one else using two different brands?
dingbat
It's not a brand issue......its the frequency in which they operate. You can't overlap operating frequencies without one interfering with the other,.
