Re: Transducer installation (Trophy 1802)
I have installed a shoot thru and mine works well, but not a Trophy. Can you easily get to the bottom of the bilge? Also, my biggest problem was keeping the transducer still while the epoxy setup on the 20 degree bottom, it just wanted to slide downhill of course. My arm was killing me as I tried to hold it until it setup. This is important as the goal is to have no air between the transducer, epoxy, bottom etc. I understand another worry is air inside the hull. One way to be sure is to launch and select your spot based on where you get a good signal/picture. I think they recommend putting it in a bag or something similar to simulate the epoxy . . .
BTW, welcome to iboats!
