transducer mounting
triumphrick
Swapped my Eagle Fishelite over from one boat to another, New boat had a transducer siliconed to the bottom of the hull, at the stern. The glass had been scraped and the mounting was pretty secure. All my other transducers have been stern mounted, but was thinking of shooting thru the hull. The Eagle says to use 2 part epoxy to hold it instead of the silicone. No problem, but if it doesn't work, can it be removed if I use the epoxy? Or can I just silicone it like the other one was?? Any advantage or disadvantage either way? As always, thanks, guys.
Lodgepole
Re: transducer mounting
If silicone worked before, I would use silicone. Epoxy would be much harder to remove without total destruction.
triumphrick
One more try to get a few responses on this. Gonna try and do this tomorrow. Thanks.
rndn
An expert in the latest Bassmaster magazine stated that you will lose 20% of the feedback by using a thru-hull transducer. He also went on to state that he doesn't know of any professional fisherman/woman who uses a thru-hull transducer.
I'm just giving you the information as it was stated in the magazine for you to make your own decision.
