Transducer Placement
mav6759
This is my first fish finder I'm installing and I wanted to know where should I mount the transducer if it matters. Is it better to mount it on the trolling motor or on the rear of the boat. I'm not sure how the viewing works on a fish finder.
mav6759
DRIFTER_016
Re: Transducer Placement
If you only want to use it when using your trolling motor put it there, other wise put it on the transom.
It matters where as trapped air that is caught under the hull while running will disrupt the signal if it runs past the transducer while under way.
Properly setup you should be able to track bottom while at full speed if it is a decent finder.
If you post a pic of the transom of your boat we can suggest where to start.
jtexas
If it's the only one on the boat, don't put it on the trolling motor, it'll be useless while under way.
How viewing works on a fish finder:
first thing to remember is, only the extreme right hand column of pixels is under you right now...everything else is history.
next, a lit pixel represents an object some where inside a circle centered directly under the 'ducer, with a diameter about 1/3 of its depth (assuming the standard 20? cone angle). that's a general rule of thumb...it could be more than 1/3 with the sensitivity turned up.
other words, something showing up at 15 feet is somewhere within 2? feet of the 'ducer, but you can't tell exactly where...could be fore, aft, starboard, port or straight down, you won't know.
third, your graph will show the shallowest bottom that the 'ducer can see. So if the bottom under your boat is sloped from, say, 20 to 25 feet, you'll see the depth as 20, and fish holding at 23 feet won't show up on your graph. That's how come you can slay 'em with a spoon bounced off the bottom, even though you don't see any fish on the screen.
The sonar isn't actually indicating the depth of suspended objects - just distance from the transducer. objects can appear slanted because of the movement of the boat, closer & closer, or farther & farther. same reason fish appear as arches.
Don't be tempted by the "Fish ID" feature (unless you have small children on board who need to be entertained). It'll give you a picture of a fish for any sonar return. Learn to interpret the echos on your own - it's way better.
mav6759
Ok but if I mount the transducer on the transom, and fish from the front of the boat won't everything that I view from the fish finder be in back of me instead in the front me were I want it to be.
Mav6759
jtexas
That's the trade-off. If you're not seeing the bottom contour while under way, you miss potential humps, ridges, structure to fish when your hotspots cool off. And you'll get tired of having to shut the main engine down, step up on deck & deploy the T/M every time you want to see what's down there. And I use depth to navigate sometimes, when I'm looking for some particular structure. Course I guess if you have GPS that's a moot point.
