Transom patch
mvs788
Thinking of replacing this section of transom with blue water Coosa board
The roughly an inch and a half thick by 2‘ x 4‘
mvs788
replacing just the center and having two joints is like trying to replace a section of a full-span bridge with toothpicks
What if I went all the way across, from gunnel to gunnel, Without going below the deck into the bilge area
mvs788
Have you done any investigation below deck for rot? Boats rot from the bottom up so you’re not really doing yourself any favors by just replacing small pieces. It’ll be weak structurally.
So I’m guess I’m looking at tearing out the entire transom well, to replace the whole transom in one piece.
mvs788
One of the braces that come up from the bottom of the boat through the transom well is rotted. So I guess I’m looking at tearing out the entire transom well, replacing the transom in one piece, and rebuilding two brand new braces.
mvs788
I worked on the Throgs neck bridge for three years, it’s more like Band-Aids! That we put on bridges.
flashback
Yep keep digging, if anything structural has rot it needs to be replaced in it's entirety not patched and most of a boat is structural.. good luck with your project
jimmbo
If you got all the rotten wood out, you could just replace what you cut, covering the joints with several layers of Glass, each new layer a couple of inches larger than the last, and a couple across the entire Transom and overlapping on the Sides. The repair is strong till the glass ends, which is why I tend to go a bit overkill. Too often I have seen a Structural Repair on Glass Hulls, where the new Mat, not even cloth or Roving, forms what is practically a Butt Joint, with an overlap of 3/4" with the old glass
mvs788
OK so, I just realized one of the stiffeners that come up to brace the transom is comepletely rotted,hollow inside.
mvs788
you will most likely find the stringers are also gone and the flotation foam is waterlogged
I’m gonna open up the old floor today, The previous on it put plywood on top of the rotted floor. It’s a 1986chawk, not sure if they used flotation foam
the deck-over is a sign of rotten transom, stringers, etc.
the deck is always the last thing to rot
welcome to the full gut-n-restore crowd.
