Chopperbill
- Mar 26, 2014
- 389
With less than a year on my Saturn the transom paint was starting to fail already. This winter I did a refurbish on it. Sanding down the old paint I could see why it failed so early. Took little sanding to get to bare wood. I wanted to use epoxy but it was $100 a gallon around here. I needed less than a half pint so that was a waste. I settled on a good gloss industrial paint. Found on sale for $7 a quart. One coat primer and two coats gray and it looks better than new. So far I have put several applications of Protect All on it so it will bead off and the sun won't deteriorate the paint. You guys with Chinese boats I suggest you do the same. China paint is not so good. Also Protect All on the tubes. Easy to apply and very good to stop sun damage. I plan on going over it diligently as long as I own the boat. (That will be until I can see my way to get a WinBoat. LOL)
