last fall when i put my boat up for the season i noticed that the screws that hold the the tilt motor were loose. it mounts to the transom of course. on closer inspection i found the the wood inside the screw holes was wet & soft. i don't know how bad it is but i fear the worst. the boat is a 1987, 19 ftr. can i remove the inside skin to see how far the damage is without disturbing the outer skin? should i remove the drive? what type of saw should i use, as i don't want to do damage to the outer skin. my plan is to remove the inner skin & rotted plywood, replace with marine ply & epoxy over it, while leaving the outer skin intact. is this possible? if this is a dumb idea, let me have it. i do not want to replace the whole transom. i've done glass work before & i think i know what i'm in for, but i want to do it correctly, & only ONCE. any advice is appreciated.
