tater76
- May 7, 2010
- 712
Re: bayliner transom saver
Wow! I rarely venture from the Chrysler/Force forum, but glad I did LOL! This is darn funny how many folks disagree :facepalm: As for the pro's and con's, I guess it boils down to experience's and general knowledge of the physics of it all. Personally, after my first tilt lock failure on a 55hp Chrysler while going down a washboard road, I invested in a De-Flopperizer. My logic is why put the weight of an expensive outboard solely on one bolt (my motor setup) and mess around with bungees and straps?. I see folks running down the road with 2011 200hp Mercs minus the saver all the time. Will that heavy four stroke stress the transom going down the road?? Probably Fed.. as for locking the steering wheel, my wheel has a set screw knob on top of the column. I simply set the motor straight, tighten the screw, and set my De-Flopperizer in place. Maybe you could drill and tap your column?? Don't do it without proper research though,
