Transom Seal Sealant?
Larry E
What type of sealant do you use between the rubber seal and the transom? Also do you put the same material in the screw holes before installing screws?
Larry E
southkogs
Re: Transom Seal Sealant?
My local Wally-World had a marine sealant that I used. I put some between the boot and the transom, and then ran a bead around the outside of the boot. Didn't put any in the screw holes, and I'm currently not seeing any leaks (just put it on this year).
