Transom woes.
starry-eyed
A little more accomplished today and nearing time to bond the new transom plate to the original stern. I was reading "Another Maine Starchief" by Oldhaven and he made reference to vertical supports located on each side at the fore end of the splash-well extending from the gunwale to the floor. My boat does not have these (they may have been removed by a PO) and I am wondering if anyone would post a pic so I can see what they look like. As I have turned the corner from tear-out to re-construction, I am looking ahead to sequence what needs to be done to put t all back together and make any improvements as I move forward.
oldhaven
Check out Post 38 pictures in my Starchief thread. If you don't have them it would not be hard to fabricate a substitute. They help locate the side panels in addition to being structural supports. Perhaps my '67 was the first year for that, but they are a good idea.
Ron
starry-eyed
Thanks, Ron. I just looked at the pics and cannot tell how they attach at the floor and the gunwale. I have some stainless and some aluminum channel that I can cut to fit. Your post #38 says that they attach also to the rub rail bolt and my rub rail attachment bolt is several inches aft of the front edge if the splash well. I am assuming that the braces are placed just at the front edge of the splash well.
Also, I have some electrolysis rot in the transom skin and intend on using J-B Weld for repairs. Is is available for use on aluminum? The stuff I saw today utilizes steel in the mixture and I was apprehensive to buy it. Also again, do you know what the coverage is for one tube of 5200? That stuff is expensive and I don't want to buy more than necessary but I want to be sure I have enough for the new transom plate, approx. 7' X 1' plus the upper "ears".
Please feel free to comment on my most recent 3-4 posts so I can stay on course. . . . .
Watermann
I don't use the fast cure 5200 which is more spendy, I use the regular and buy a construction tube of it at a time for my projects at 16 bucks a tube I can't say that's expensive.
I used Marine Tex on my transom skin for the pitting but the steel reinforced JB hasn't been seen as a problem until you want to sand it that is. :lol:
starry-eyed
Thanks, Watermann, I will get the slower cure, the stuff I saw yesterday was $24 for a regular size (caulking tube). Will one construction tube be enough to butter the new plate?
Watermann
Yes, it just needs to cover with a light layer, over do it and that stuff will run out and be wasted.
starry-eyed
I just returned from a three week RV trip and got back on the Starchief again. Prior to leaving I filled all of the rot and unnecessary holes in the original aluminum stern and painted the interior surface with POR 15. Then, after an application of metal prep, I attached the new aluminum transom plate to the original with 5200 and a mix of clamps and bolts which was allowed to cure while away on the RV adventure.
starry-eyed
The new transom board was treated with two coats of West System epoxy and is now ready to slide into place. All of the holes have been pre-drilled through the wood and the newly attached transom plate.
Watermann
Looks good, new clean AL always does tho :lol:
starry-eyed
The work has been progressing in spurts, its hard to stay focused between RV camping and hunting season. I cut, shaped, and installed the king starboard over the freshly painted transom and 1/4 inch transom plate and thru-drilled the remaining necessary holes. The splash well has been re-installed and repainted and new gunwale end caps were installed. Its beginning to look like a complete boat again!
Watermann
Nice work, really looks good and well done. Should last about forever too :thumb:
starry-eyed
FINALLY ! ! ! The trolling motor bracket has been installed onto the completed transom, everything sealed, caulked, and painted. Its been a looooong three years with many delays and frustrations, but a splash is imminent! I couldn't have done this without iBOATS and my fellow Stracrafters so a BIG SHOUT-OUT to all that guided me thru the process, especially Waterman, jbcurt00, GA-Boater, Tnstratofam, oldhaven, Scott Danforth, and No-AH. I put the ear muffs on the Johnson 70 for cooling and within a few minutes she was purring like a kitten. Next I'll clean construction dirt from the rear deck and cabin, polish the wood, test the electrics and electronics, and prepare for the SPLASH PARTY.
Watermann
Fine work you've done there :thumb:
It's great to see another old Chief ready to hit the waves once again in all their glory.
fetch
starry-eyed
Prior work on the boat includes a 1/4 inch aluminum sub-deck over-laid with 1/2 inch marine plywood, a complete re-wire, replacement of the cabin bulkhead, rebuilt helm, and a radio console with new switches. I used a combination of mahogany, teak, and cherry for all of the woodwork.
starry-eyed
Here's a close-up of the radio console which includes a marine radio, a CB radio, navigation and deck light switches, a Humminbird, and several fuse blocks.
starry-eyed
The helm rebuild consists of new gauges (tach, speedo, volt meter, and fuel), a new wheel, and another switch panel for the horn and bilge pump, plus additional fuse blocks. I also installed a AM/FM cassette radio with speakers in the cabin.
starry-eyed
We are off to Dworshak Reservoir in North Idaho for the long-awaited splash!
starry-eyed
She floats and goes, it must be wake Wednesday! A beautiful day for a boat ride......
