transon height
tbird175
I am looking for a good 20" transom hull. I have found several that I like on C-list but they have 25" transoms. I have been told that usually 20" transoms mean that they are salt water boats. Not that it matters since I will be using my engine but is this true?
Bob_VT
Re: transon height
Nope. Transom height is not related to water type.
If you are looking for a 20" transom....then that is the target. Obviously you have a 20" leg on a motor;) that needs a boat.
Keep shopping.
tbird175
Re: transon height
Keep shopping.
Thanks Bob_VT, I am still looking. Hopefully as summer winds down, boats with bad engines may become easier to find and maybe cheaper LOL.
dingbat
Re: transon height
Actually, the opposite is true. 20" transoms are typically found on "bass boats" and "runabout" configurations. 95% of the SW boats are either 25" or 30" transoms.
Chris1956
Re: transon height
Tbird, Transom heights tended to get higher over the years, especially as the higher HP motors became available. Early boats (1950s) has 15" transom, boats in the 70s had 20" transoms and newer boats have 25" and 30" transoms. If you have a 20" motor(longshaft), you will find a boat for it. You might narrow your search to older boats(70s - 80s) since 20" transoms were most popular on them.
tbird175
Re: transon height
thanks Chris1956, good information. I believe that I will find one this winter.
