mr300z87
- Sep 15, 2010
- 701
So here is my situation, I have a 1989 Invader V210 cuddy cabin that is in near perfect condition. It has been in dry dock for the last 2.5 seasons because of a trashed 5.7L and a running Sea Ray Sundancer 250. See link for back story
https://forums.iboats.com/forum/eng...-cylinders-1-and-3-after-overheat-need-advice
In a perfect world I would have the correct vintage 5.7L built or purchase a reman long block, swap all the hardware and drop it in. Knowing the boat has little value not running and maybe $3 to $4K running I want to be in this for as little as possible both monetarily and in time. I have found affordable 5.0L EFI Engine complete drop in that I am going to look at tomorrow night. My plan is to do a compression test and possible fire it. Since I know this boat was offered with everything from a 3.0L to a 5,7L and performed well with a tired 5.7L I am not concerned about the 20 less HP the 5.0L has.
First off I an not really a big fan of the GM 5.0L engine, that aside, my concerns are will the EFI motor be plug and play to my boats bullet connector? Also this boat is equipped with a Bravo drive and will need a raw water pump added. What parts will be need to add this, Pump body looks the same, bracket is different, pulley is different, different belt and some hoses, am I missing anything? This alone could drive the cost up to much. Will the ECU work ok with the 1.5 ratio Bravo drive? Re prop needed maybe?
Last question how do I go about getting this engine to fire on the ground? I know how to get this engine to spin but what needs power to run?
I know this is kind of a backwards swap but would like to get this boat fixed and out of my yard. The thought of parting her out has crossed my mind but she is to nice to do that to beside I like doing this kind of project. Now if the temps and humidity would drop I might be able to get the 5.7 out.
As always any advice is always appreciated.
Mike
Mike
