trim and tilt switch question
fun123fun321
I have a tilt switch on the shifter at the console and a up/down tilt switch on the side on the motor. How come I can only tilt down the motor from the shifter, but i can tilt up and down from motor switch? Is this normal or there is a problem with the switch on the shifter? <br />Also, when I lift the motor up, fluid leaks from the top of the cyliner where the shaft push the motor up. <br />The plastic O-ring seal looks worn. Do they sell part for this, Is it easy to replace? <br /><br />I know nothing about boats and motors. Please help me out<br />Thanks in advance!
y not
Re: trim and tilt switch question
Get that control unit switch checked out. and get that seal fixed pronto
fun123fun321
Thanks Ynot<br />Its a bad switch. I jsut replaced it.<br />Do you know what type of fluid i can use for the power tilt? <br /><br />Thanks in advance.
mulliganmagic
Hooty
Yeah. Be sure and read the instructions for your engine. Some need to tilted all the way up, some need a support. Don' try it 'til ya know for sure.<br /><br />c/6<br />Hooty
