Re: trim but no tilt?
I've attached a wiring diagram of the trim system. Yours may have two relays or one, but it doesn't matter.
There will be a 2 wire cable (looks like a black extension cord) running from the motor (limit switch location) with the hydraulic lines to the pump. You need to disconnect the two in-line connectors, then connect the purple wire directly to the two blue wires. This takes the limit switch out of the circuit and allows full range of operation.
As you can see, this type of system used a 3-button control. When the middle AND top button are pressed at the same time, the limit switch is bypassed, allowing the motor to
tilt fully up. The normal operation uses the middle button to
trim up and the bottom button to
trim down.
