chrysler 700 skier 70 hp 1979. I've been adding oil to my tilt/trim regularly. I couldn't find a leak anywhere. Recently found the leak... I believe it is called the trim cylinder. There are 2 pistons which makes the motor go up and down. No problems there. There is a third cylinder that looks like it goes in and out, but only when the motor is most of the way down. Oil is coming from this shaft. Looks like there is a seal or something that has gone bad around this shaft. Can the seal be replaced or does the entire trim cylinder need to be replaced.
Thanks.
Number on the cylinder is 449545-2
Thanks.
