Trim Limit setting. 20deg?
YOBE
Hi,
Just re-installed my MC1 sterndrive on the boat. The Trim-sensor was just a dummy (also no gauge in the boat).
But there was a Trim-limit switch that was "bridged". So would like to put it back as it should.
I read somewhere that a 20° - 25° angle is the max you should go while boating (to prevent damage on the U-joints).
Is this correct? Meaning should I adjust the limit switch to this angle?
And how do you then bridge this switch when boat is on trailer? Or do you also try to limit the angle to about 20deg? I read some raise to higher position. But I'm worried for damaging the bellows.....
PS: Is there a big added value to have/install a Trim-gauge + sensor?
Thanks for the feedback
I think it's closer to 4 degrees per u-joint.
So on a double card on joint, +8 up to -8 down
you know there is a specific dimension called out in the manual to set the trim limit to.
Scott06
Hi,
Re the trim gauge having grown up with boats that didn’t have them or current boats were non functional or inaccurate I wouldn’t waste the time to install it.
You end up trimming based on load number of people and how smooth the water is so no gain in my opinion
I think the A1G2 dimension was 21.5
The MC1 has a different measurement. Refer to the manual
