Trim not working, just clicks
Mikered3500
Trim won't work. 89 Johnson 225. I replaced the relays and it still just clicks .the wiring looks correct .I can't forgot it out. Any help appreciated .thanks
alldodge
Either motor is bad, pump is stuck, or bad/corroded connection
boobie
Give the motor a couple of raps with a screwdriver handle and see what happens.
Mikered3500
I'll check the fluid and tap on it tomorrow. Just got home and didn't have service. I'll post on here what happens. Thanks
Mikered3500
So....pulled the trim motor off, it was seized, fluid was low and it needed replaced. New motor, new fluid topped off and it was good as new.
