Trim pump help
racerman16
I have a 84 formula 25pc. It has a 5.7 and alpha one outdrive. This past weekend the out drive would not come up. It would go all the way down no problem. I pulled the lines off at the pump and if I hit the down button it will spray a steady stream out. When I hit the up button the motor just runs but no fluid will come out of the pump. Is the pump bad? If not what am I doing wrong? Also, in looking for a new pump, whats the difference between the pump with a plastic resivoir and the one(like I have now) that doesn't have the external plastic resivoir? Thanks.
Re: Trim pump help
Ayuh,.... Is there oil in the pump,..??
I believe there might be a difference in the tubin' fittin' sizes, 'tween the pumps,...
If so, worse case is replace the hoses to the manifold,...
racerman16
Re: Trim pump help
Yes pump is full according to the dip stick. Everything was working great then it quit going up.
dswi
Re: Trim pump help
What kind of oil goes in the resivoir?
