Trim pump noise. Listen then comment please.
Grub54891
Re: Trim pump noise. Listen then comment please.
Sounds like the motor is going south. You should be able to get the motor and not the whole pump. However I've seen em run servral years sounding like that. Is it full of oil?
Grub
Bt Doctur
It`s a dry bearing in the end cal or at the end that goes into the pump body.
grub does have a point, they can run for years like that.
04fxdwgi
Odd. Sounds just fine going up, but like crap going down.
