Hello Everyone,
I have a 1974 Slickcraft with a Ford 302 Mercruiser 188HP motor. The trim pump has been giving me problems on an off for a couple of years and recently I noticed a leak. Turns out the o-rings falling apart between bottom casing bolted to the pump body. I replaced them and hooked all wires up again and everything worked great for a couple of weeks with no leak. Then I started just getting a click sound with no movement. I double checked the wires and ended up hooking everything up and then would work for a little while then nothing again. Now I can hear the sound of the pump running normally but no movement on the motor. Fluid is good, power looks good, sounds like it is running but the motor won't move. I am assuming the pump is shot and I will replace. However if someone out there has experienced the same thing please let me know and what you did to resolve. Thanks in advance!
