Oshkosh1
Ensign
- Jun 8, 2009
- 968
So looking through EVERY possible schematic available, I have not found my setup for trim wiring. I suppose it was unique to Wellcraft or something. What I have is a dash mounted, two rocker button(top is "Tilt"...a momentary on/off) (bottom is "Trim up/Down"...a momentary on/off/momentary on).
Now... The TOP rocker has only two spade connections, to which are connected as follows(looking at the back)This allows me to raise the unit from full down to full up...which I can with no problems.
L_______________R
Blue____________(Empty)
Red(Jumper)_____(Empty)
(Empty)_________(Empty)
The BOTTOM rocker has six spade connections connected as follows (looking at the back of the switch)
L______________R
(Empty)__________Red(Jumpered to top switch)
(Empty)__________Green
Purple____<->___ Purple(jumpered together)
Now...with THIS arrangement I can LOWER the unit pushing trim "down" again...no problems.
The problem I have is that I cannot use the trim "up" to raise the unit to the stop limit, I've been trimming manually using the "Tilt" switch.
Any help/suggestions are appreciated....
L_______________R
L______________R
