When a boat leans to the right while on plane what is the proper method of correcting it using the trim tabs? Press the bottom side of the right trim rocker switch (bow up)? If the trim tabs are already in the full up position, how can this help? I was told to start out each trip with trim tabs set in the full bow up position. Is this correct? If the boat leans to the right, do you ever hit the left trim tab (top of rocker switch) to lower the bow on the left?
