can the Trim system be tested even when the drive is not installed?
J juliolop Seaman Joined Nov 3, 2015 Messages 65 Jun 3, 2016 #1 can the Trim system be tested even when the drive is not installed?
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,531 Jun 3, 2016 #2 you mean can you extend and retract the rams? - yes however that will only tell you the pump and electrical work, not if the check valves, etc internal to the pump are up to snuff.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,159 Jun 3, 2016 #3 can the Trim system be tested even when the drive is not installed? Click to expand... Ayuh,.... Sure,....
